Is evo 212 suitable for OC?
SahajJain
Commendable
Apr 25, 2016
19
I have a fx 4100 which is bottlenecking my gtx 960. So I OC it to 4ghz and now there is a vast difference in performance and max temp is 65c on stock cooler. But if I OC it to 4.2ghz I get even more performance but the max temp rises to 82c. If I buy the evo 212 cooler how much OC will it withstand and what will be the max temp?
It's not a great choice for an FX-series processor because they get really hot. If you want to overclock further you will need a bigger cooler. But, saying that, if I were you I'd stay somewhere in the 4.0-4.2 realm because even with a much more expensive cooler you're not going to get massively greater performance.
I agree. WIth the money you spend to get a huge air cooler like noctura's You would be better served getting a better FX (6xxx or 8xxx) CPU and something like the cryorig H7. It would be a bit more expensive though and assuming your mobo could handle one of those.
It is also an option to switch to an intel build as well
The thing about that CPU is, even if you bring it to 5Ghz, an i3-6100 would still outperform it.
That said, I don't think you should be buying a new cooler for that, rather saving for a new build, a haswell one will do and you can reuse your RAM.
Is there any other way I can bring down the temp at 4.2ghz like undervolting or a high quality thermal paste. I am currently using Cooler master v1 IC value. I'm not in any position to upgrade my PC or even buy an expensive cooler. If there is no option I will stick to 4ghz OC since 65c is pretty good for a stock cooler I think.
No, to overclock past about where you are you'd have to start overvolting. You might get 1-2C lower with the best possible paste, but that's not going to make a big difference.
