Is G-Sync compatible with my monitor
  • Thread starter Thread starter Deleted member 1480971
  • Start date Start date
D
Guest
My GPU is Gainward Geforce GTX 750 Ti, whick supports G-Sync but my monitor doesn't have Display port 1.2
You don't probably know this monitor because it's a brand only found in Greece, Turbo x TX215ELM
If my monitor isn't compatible, then which Sync should I use?
This site list's only these monitor's as being gsync compatible yours is not listed. It does however list some possible mods, hope this helps have a great day.
http://www.blurbusters.com/gsync/list-of-gsync-monitors/
