Z zezo1337 Commendable Oct 24, 2017 2 0 1,510 Oct 24, 2017 #1 Here's My PC information: - Ram: 2GB - MotherBoard: MS-7592 - CPU : Intel Core 2 E7500 - OS: Windows 7 - Display Size: 1000 x 800
Solution clutchc Oct 24, 2017 Yes, but you need up upgrade your system RAM. With only 2GB, you will run into memory problems.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Oct 24, 2017 Solution #2 Yes, but you need up upgrade your system RAM. With only 2GB, you will run into memory problems. Upvote 0 Downvote Solution
