Echoceres Honorable Jul 13, 2013 478 0 10,790 Sep 11, 2018 #1 Is GIGABYTE B450 I AORUS PRO WIFI decent? Planning on getting this for my mini itx build. This is the cheapest and only option I got because of lack of pc components on my country.
Solution Z Z zyh1987 Sep 11, 2018 as long as you run it with some kinda of air flow, it should run fine. it uses pretty decent vrm, 4 way (ir 3556, rated for 50 amp each PowIRstage)
Z zyh1987 Estimable Mar 16, 2018 2,146 9 3,065 Sep 11, 2018 Solution #2 as long as you run it with some kinda of air flow, it should run fine. it uses pretty decent vrm, 4 way (ir 3556, rated for 50 amp each PowIRstage) Upvote 0 Downvote Solution
