[SOLVED] Is GTX 1050 suitable replacement for GTX 450
Albie2351
32
Is Gigabyte GeForce GTX 1050 Ti 4 GB GDDR5 128 bit Graphics Card (GV-N105TOC-4GD) a suitable replacement for Nvidia Geforce GTX 450 on a B85M E45 motherboard with a 500w power supply
Thank you
yes but still not decent enough for todays standards if you know what i mean. Its not worth that $150.
Thanks for that, What would you recommend? Actually I'm wondering if I need anything better as I don't indulge in gaming but do use Cyberlink Power Director very frequently to produce DVDs and edit video so would I benefit for an upgrade?
Thank you
RX 570 or GTX 1650 Super solid entry level gpu for the stuff you need to do.
