Is GTX 1060 6 GB WF 2 compatible with Asustek P8H77-M and Warmachine X Case?
Physically measuring the space for a GPU (from the rear expansion brackets to the drive cages) will give you a definitive answer.
That GPU is 223mm
Your motherboard is mATX and 24.5cm x 24.5cm (245mm)
The GPU won't even reach the end of the motherboard. It'll fit.
That GPU is 223mm
