MultiGaming :
anti-duck :
MultiGaming :
13thmonkey :
and don't get a ti, unless they are going cheap the 1070 is slightly better.
But is the 1070 compatible with my system cuz i did a other review here with the 1080 and it was not compatible with my system.
Both the 1070 and 1080 are compatible with your system, they're just going to be held back by your CPU.
but the guy who said it wasnt compatible said also it wouldnt be any better if i got an 1080.
There is no compatability issue. However, your CPU is weak, any CPU's you can get for your mobo will be weak. Given the cost of a 980ti and a new FX processor I would recommend getting a 1070 and a new cpu/mobo/ram, should be a similar cost in total, and much greater performance.
And we need to understand your PSU details.
