is HD 7750 the best graphics card that doesn't need auxilary power?
sandro9970
37
Also, it would be cool if you guys provided some links with the best price/quality ratio.
On the side note, which one of these cards is the best?:
http://www.amazon.com/HIS-Radeon-Express-Graphic-H775FN1G/dp/B008OGBG6Y/ref=sr_1_15?s=electronics&ie=UTF8&qid=1390477059&sr=1-15&keywords=7750
http://www.amazon.com/Diamond-Multimedia-Radeon-Graphics-7750PE51GV/dp/B00C694G3K/ref=sr_1_16?s=electronics&ie=UTF8&qid=1390477059&sr=1-16&keywords=7750
http://www.amazon.com/HIS-Turbo-GDDR5-Graphics-H775QNT1G2M/dp/B0089XT6E6/ref=sr_1_9?s=electronics&ie=UTF8&qid=1390477059&sr=1-9&keywords=7750
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121633
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150663
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161418
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161427
Thanks for your answer :) I'll try to get the GTX one, but I'm not sure. On average, what FPS would I get while playing Battlefield 3 on Ultra @ 1440x900?
You're not going to be playing BF3 on Ultra at 1440x900 very well to be honest with you (it's always hard to give estimates but with custom settings with textures on ultra and the rest on medium/high you should get playable results)
650
http://www.tomshardware.com/reviews/geforce-gtx-660-geforce-gtx-650-benchmark,3297-7.html
http://www.techpowerup.com/reviews/MSI/GTX_650_Power_Edition/8.html
7750
http://www.tomshardware.com/reviews/radeon-hd-7770-7750-benchmark,3135-6.html
http://www.techpowerup.com/reviews/ASUS/HD_7750/8.html
I listed the 650 as an alternative, but the cheaper 7750 is probably your best bet, it should perform similar if not better than the 650 in BF3
Out of curiosity why do you want one withotu power connectors and what are your budget constraints?
I have a 400W low-quality PSU without external power cords, and my budget shall not exceed 110$.
You can get an adapter for the video card cables, unless you mean you have no free power connectors at all. Many cards actually come with such adapters.
For $100 you can get a 7770 but it's it's really a low quality PSU it may not handle that card well. The 7750 is slower but is very close to the 7770 in price. You may want to stick with the 7750 just to make sure the system is stable.
