Is heat output a important factor in building a computer.
Just wondering what the community feels about heat output. lets say i have a fx 8350 and r9 290x both put out a lot of heat but lets say i have a nice negative airflow, a h100i, and a vapor x cooler should i still be conserned about heat.
dust is important, if dust is clogging your vents/heatsinks, cooling is drastically reduced and fans need to work harder. Anyone who builds there own system would be dusting frequently if they're system is in a dust prone room. Even more frequently if they tamper with OC'ing or have a windowed case to show off the internals.
Though unless you have big holes/slots from where dust can get sucked in, it will take a while for it to build up to a point where it affects cooling.
Then there are those that build a system and don't care, leave it to accumulate till it's visible and noticeably affecting cooling performance.
But these are super-fine dust particles in question, so it will be many months in most circumstances, before it may seem...
You want positive airflow. Negative airflow pulls in more dust. Positive stuffs in more clean cool air.
Pretty open-ended question, so here's how I feel: Most components were designed with their own heat output in mind, and are designed to handle it without a problem. If you want to be safe, though, then try to keep temperatures a fair amount under their rated limits... it's like running a car at 100% all the time: sure, it will work, but things might just fall apart prematurely.
In terms of your build specifically, you have more than enough cooling power. Just be smart about your fan placement - don't have six fans running exhaust or something - and you'll be good to go with no problems.
Hope you have air conditioning... I know my setup does a nice job of heating the room up, and it's just a tiny little thing in comparison to what you've got there. Unfortunately the better your cooling system is, the more heat it blows into the surrounding area. :)
a water cooled gpu would cut the heat produced drastically. Some aftermarket gpu companies like msi still cover warranty if the cooler/heatsink on it is replaced too, as long as you fit it back on when sending it back is need be
NZXT kraken G10 is quite popular and very cheap http://www.overclockers.co.uk/showproduct.php?prodid=HS-007-NX
http://www.anandtech.com/show/7719/nzxt-kraken-g10-review-liquid-cooling-for-your-gpu
Well a 60-90C r9 290 is comfortable as long as ot's not drastically affecting the cpu temps.
Only really a concern for overclockers who want lowest possible temps for further OC'ing and stability
What kind of temps we talking? If i was concerned in my case (enthoo pro) I'd add in another intake at front and make use of top with exhausts
what is better negative or postive
would aim neutral 😀 but if had to go one way, I'd go negative, as I'd want the hot air exhausted faster,
-hot air exhausted faster, gpu/cpu fans can have cooler air to use more efficiently.... la la la
-maybe the negative aids in intake speed?
But ofcourse that's a whole big debatable topic
Actually... it is the intakes which bring in dust, so technically, negative would be less dust than positive lol
This is what dust filters are for.... if dust is still a problem then tidy that room and vacuum more often!
You want positive pressure inside the case.
That way the only intake is via the intake fans and these have dust filters.
If you do negative pressure any gaps will draw air and dust into the PC. With positive these gaps push air out keeping dust out.
I believe my point is proven here.
hmm, seems true too,
dust filters, regular cleaning with compressed air cans, vacuum room more often etc... We're talking about the airflow and temps here, not all other variables. It's like talking about which cooler performs best but using stock TIM in some and IC Diamond in others lol
If dust wasn't a factor, which would you prefer? rather have the hot air moved out faster instead of circulating back into coolers i.e. negative
But these are super-fine dust particles in question, so it will be many months in most circumstances, before it may seem worth cleaning, my dustiest tower is an antec silent case which is fine for half a year in the loft.
Dust will be an issue in both -ve/+ve,
IMO, choose which provides better cooling and have a routine of cleaning dust regularly.
I use can of compressed air ($12 for 4x 500ml) to blow it out and hold a vacuum hose nearby for it to be sucked away rather than circulate the room, only to be sucked back into the case quicker
If you want a better dust solution, find the major places your case will allow dust through and have dust filters fitted. Example> http://www.frozencpu.com/products/16427/ffi-102/FrozenCPUcom_Premium_Dust_Filter_Material_500mm_x_400mm_x_3mm.html
When you turn your pc off, cover it up with an anti-static material cover.
To put my perspective of negative flow visually, think of a case where smoke is used to represent heat. With positive, the smoke will be circulating round longer before it is exhausted. With negative, it is exhausted quicker for intakes to bring in cool air and circulate that cooler/'non-smoky' air, aka,heat is dissipated faster than cool comes in rather than coll coming in faster, mixing with hot before its exhausted (to an extent, just being visually descriptive)
Both types of airflow are favoured, seems personal preference, Link mentioned previously to other post validates both are used between 680votes.
Go for whichever you prefer. Though ultimately, there are tiny differences in performance and what will matter most as long as it's a decent airflow case with filters in the right places, is the performance of the individual cooling components.
Yeah, another example, architects in my dad's construction companies use £1-2k towers, very often in shipping containers used as offices 'on site,' which get very hot half the year. Either airflow works fine, most often can't add/adjust fans as i do not own them but the cases need alot of custom dust filtering fitted to protect their components from construction debris dust particles which can do damage.
Not sure what the material used as filters is called but they have alot of the 3mm stuff and is great for both filtering and allowing airflow. Some owners remove it later, some keep it for their future needs
Just a complementary service my dad enslaves me to do =( nice to see different builds and the challenges given though
