Question Is HP G1 800 motherboard not compatible sith 8pin connection PSU?
Apr 11, 2019
11
I was planning on buying AMD RX570 Nitro+8gb but someone has told me that my current motherboard (HP G1 800) is not compatible with a 8 pin connector PSU
Apr 11, 2019
11
So what should I do?
I don't have budget for replacing my motherboard... Currently I have budget for my Graphics Card and a new PSU
Apr 11, 2019
11
I think what Traditore means is that......you buy the proper PSU for your GPU......and you buy that adapter.....which will connect to your motherboard on one end....and the PSU on the other end.
You will be using YOUR motherboard.
Thanks mate.!!
So I just need to buy an adapter and I shouldn't be concerned about anything?[/QUOTE]
Similar threads
