Question Is HWmonitor reading my clock speed wrong?
Dylanblaha
12
So I have a Ryzen 7900x 12c/24t and it never really goes above 5.6 GHz (I think I’ve seen it touch around 5.9 GHz though).
However, I was playing a game and watching YouTube in the background and dragged something to the other monitor and noticed it read a max value of 7.93 GHz across almost all cores except for two, which got up to 6.48 GHz and 6.3 GHz
Here’s a pic to show it
Have you guys had any problems with HWmonitor? It seems reputable.
Also, if my clock speed is actually going up to 7.9 GHz and I have a crazy processor, is this something to be concerned about? BIOS setting are all default, and I never tweaked with the CPU. It’s cooled with an AIO and never goes above it’s intended 95 Celsius.
Ram is ddr5 6000mhz XMP profile
Clock numbers are a rate.
Samples are taken with some frequency and a calculation is done.
If you happen to hit the sample and the frequently within an interval, you can get a momentary high clock rate.
The maximum number is just that, the max observed.
Now, if you saw an individual rate continuously high, that would be worrisome.(or not)
i have the same issue my 7700k can go 29k-30k mhz,only during game tho,i was like whattt..no way.temps ok tho
n then i switch from "high performance" to "balanced",nothing
n then i reset bios,i thought something change in c state,nothing
n then i downgrade hwmonitor from version 1.53 into 1.50 n it work....no silly 29k-30k ghz anymore lol
Reactions: CountMike
Latest posts
