D distan81 Reputable Nov 4, 2014 3 0 4,510 Nov 25, 2014 #1 As far as I am aware the only difference between 5820k and 5930k is that 5820k has only 24 lanes, where 5930k has 40 lanes, which makes no difference, when using only one GPU. Am I right here? Thank You all for any information.
Solution Francisco Costa Nov 25, 2014 And the 5930k is also clocked higher, but you can always overclock the 5820k to 5930k levels. the 5820k is the obvious choice for one GPU.
Francisco Costa Distinguished Nov 16, 2013 1,440 0 20,410 Nov 25, 2014 Solution #2 And the 5930k is also clocked higher, but you can always overclock the 5820k to 5930k levels. the 5820k is the obvious choice for one GPU. Upvote 0 Downvote Solution
D distan81 Reputable Nov 4, 2014 3 0 4,510 Nov 25, 2014 #3 Yes You are right. Well I am running my i7-5820k at 4.4 MHz stable. Upvote 0 Downvote
Francisco Costa Distinguished Nov 16, 2013 1,440 0 20,410 Nov 25, 2014 #4 distan81 : Yes You are right. Well I am running my i7-5820k at 4.4 MHz stable. Ghz* 😉 Don't worry then, you have a great CPU. Upvote 0 Downvote
