BlackBurn98 Reputable Feb 23, 2015 41 0 4,540 Mar 4, 2015 #1 Hey! As the title says, is Intel Pentium G3240 64-bit or 32-bit? Like, will it support windows 8.1 64-bit? It would be good if you provide a source to your answer as I've heard a lot of different answers a few days back. Thanks!
Solution USAFRet Mar 4, 2015 64bit http://ark.intel.com/products/80796/Intel-Pentium-Processor-G3240-3M-Cache-3_10-GHz "Instruction Set 64-bit"
AdviserKulikov Honorable Jan 13, 2015 1,099 0 11,960 Mar 4, 2015 #2 No major manufacturer makes 32-bit only processors for desktops anymore. So it supports 64 bit. http://ark.intel.com/products/80796/Intel-Pentium-Processor-G3240-3M-Cache-3_10-GHz Check under the Intel® 64 category. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,617 22,161 184,590 Mar 4, 2015 Solution #3 64bit http://ark.intel.com/products/80796/Intel-Pentium-Processor-G3240-3M-Cache-3_10-GHz "Instruction Set 64-bit" Upvote 0 Downvote Solution
BlackBurn98 Reputable Feb 23, 2015 41 0 4,540 Mar 4, 2015 #4 Thanks for your quick replies @USAFRet and @AdviserKulikov Upvote 0 Downvote
