Hi, my system is:
ASRock Z270 Killer/sli
I7 7700K 4.2GHz
Cryorig H5 Universal
64GB DDR4 3200oc
RX590 8GB +Nitro
EVGA 850 G2
Intel 660p NVME M.2 512GB
Case fans (Thermaltake Riing RGB Plus x3)
Case: Kolink Punisher
Hello, I've been trying to work this one out for over a week now with no luck. The web has proven to be a good source of information, but it brings me back to where I started time again. I installed the software supposed to run the led rgb on the case fans, and it comes up with the same error that so many are getting when they try to run the program. The error code I keep getting is "Could not find fan controller please check fan controller is connected" Error code H_0x0001. I've been into the bios to see If I could enable the USB 2.0 9pin header that the controller connects to. Consequently, the header is enabled and showing as empty when connected to the controller. I've tried accessing different versions of software that'll run the rgb on the fans, but most of the links are dead up to v.1.28 and the thing is, there's power going to the fans, I mean they're operational when I boot and run through the controller but no rgb, and the system isn't recognising them. I have tried different pin configurations on the USB headers, with no luck. I thought that uninstalling C++ redistributable 2017 was the answer. And again once I had, there was still the same error code showing. Any help with this would be greatly appreciated and many thanks in advance.
I7 7700K 4.2GHz
64GB DDR4 3200oc
RX590 8GB +Nitro
EVGA 850 G2
