Is it best to RAID 0 the same SSD rather than using separate?
bingaloman
493
I have 2 Kingston 120GB SSD and those are the only drives my PC is going to be using.
Is it best to just put them both in RAID 0 to combine as one drive?
And from what I understand, RAID puts 2 drives and combines storage and creates it as basically one drive right? So if I am right on that does that mean it will make just one drive such as C drive instead of making C and D?
I have never done this before.
Thanks for any help!
Because if one drive fails in a raid 0 both drives fail. You need to have good backups so you don't lose everything on both drives if one fails. The only thing you will really notice is load times for games or projects you are working on with Raid 0. My setup gets about 1.0GB/sec rates with the 2 SSD's in a raid 0 and other than 1 second load times in Skyrim I really don't notice much difference.
The reason I ask is because I don't want to have to manage what download goes in which drive as having one letter drive makes it alot easier.
But you say it doubles the chance of failure, why is that?
Ah ok I see that makes sense.
Thanks for everyone's help, I guess I will just put em as separate drives then.
