Hi,
I need some expert advice.
My computer appears dead. For pressing the power switch there is a short flashing of the LEDs and a quarter turn of the fans and then it stops completely. No beep.
The computer is custom built to calculate numerical models, so it doesn't have a video card, dvd or any extra peripherals. It was running very fine and a lot in the past two years. There is no overclocking.
I left it under full load (8-core AMD FX 8350) for a week and I was away when it crashed. So I don't know what exactly happened, it was already in its dead state when I returned.
My first guess was the power supply, so I ordered a new one. It showed the same symptoms. The next guess was the motherboard itself. I started unplugging everything from it, one by one, nothing helped. In the final move I had only the CPU and its cooler on. When I unplugged the CPU power cord it came alive, the CPU cooler fan started spinning, but a second after there was a small flash of light followed by a smell of burn from under the CPU cooler, but it came from the motherboard. There is also a thick coil with only partial coverage. May it be a short circuit there? There is no burn mark or any visible defect.
I did not try to reset the BIOS.
After plugging in everything it shows the same behavior as before.
I wonder if anybody experienced anything similar and have a suggestion what is wrong. Likely the motherboard, or maybe the CPU, which is still under warranty.
Specs:
FSP 500-60APN 85+ 500W power supply
Scythe Mugen 4 CPU cooler
Asrock 970 Pro3 R2.0 motherboard
AMD FX-8350 sAM3+ CPU
Kingston HyperX Predator 8GB DDR3 RAM
Specs:
