I Ikmal Izzat Johari Reputable Mar 1, 2015 27 0 4,530 Feb 10, 2016 #1 http://imgur.com/a/0aTBz I'm not sure. It looks like dead pixel but seems as if its not dead pixel. help pls?
Solution ffg7 Feb 11, 2016 when did this showup? monitor should still be under warranty so check with BenQ site to see on warranty status.
Shaun o Illustrious Oct 7, 2007 6,113 1 41,960 Feb 10, 2016 #2 If the place where a pixel should display the color of the screen stays the same, from blue, red, or green. white, to black. It`s a dead pixel, or a set of pixels of the LCD matrix. Matrix damaged or imperfect. If it stays a set color while cycling through RGB, it is a stuck pixel. Upvote 0 Downvote
I Ikmal Izzat Johari Reputable Mar 1, 2015 27 0 4,530 Feb 10, 2016 #3 Shaun o : If the place where a pixel should display the color of the screen stays the same, from blue, red, or green. white, to black. It`s a dead pixel, or a set of pixels of the LCD matrix. Matrix damaged or imperfect. If it stays a set color while cycling through RGB, it is a stuck pixel. I did upload 4 pictures showing in white, red, blue , green, the colour appears to show but it appears grayish in white backgprund Upvote 0 Downvote
ffg7 Judicious Apr 7, 2015 5,924 2 34,665 Feb 10, 2016 #4 how long have you had this monitor? what is the make & model# of the monitor? Upvote 0 Downvote
I Ikmal Izzat Johari Reputable Mar 1, 2015 27 0 4,530 Feb 11, 2016 #5 ffg7 : how long have you had this monitor? what is the make & model# of the monitor? BenQ EW2440L. I had it close to one year I think Upvote 0 Downvote
ffg7 Judicious Apr 7, 2015 5,924 2 34,665 Feb 11, 2016 Solution #6 when did this showup? monitor should still be under warranty so check with BenQ site to see on warranty status. Upvote 0 Downvote Solution
