My GTX 660 2GB heats up to 78°C with default fan curve so I changed it to make it 80% when it hits 68°C it's very little bit noisy when it touches 68°C and it is fine for me... Is there anything that would damage my Graphic card due to this?
Well, for me, i would like to clean the gpu completely. Starting from cleaning the pcb from dusts, the heatsink and fins from dust (sometimes i wash it lol but dry it afterwards), and clean the fans. Just dont tolerate any small dusts or dirt. after that re paste it. that should help you from getting lower tempsMy GTX 660 2GB heats up to 78°C with default fan curve so I changed it to make it 80% when it hits 68°C it's very little bit noisy when it touches 68°C and it is fine for me... Is there anything that would damage my Graphic card due to this?
Iam not good at removing parts to clean now after adjusting the fan curve it's fine and stays below 70°C iam asking is it bad for the Graphics card due to the fan speed?Well, for me, i would like to clean the gpu completely. Starting from cleaning the pcb from dusts, the heatsink and fins from dust (sometimes i wash it lol but dry it afterwards), and clean the fans. Just dont tolerate any small dusts or dirt. after that re paste it. that should help you from getting lower temps
My friend did the same except the pcb was still dirty, decided to wash the whole pcb (dont try and do this), and now his 750ti is far more cooler.
I would refrain from washing any of the parts if you're not sure of what you're doing or comfortable with the process. Dusting off with a brush and air should be enough to keep it decently clean.Iam not good at removing parts to clean now after adjusting the fan curve it's fine and stays below 70°C iam asking is it bad for the Graphics card due to the fan speed?
