[SOLVED] Is it normal for a GTX 1060 to have sudden frame drops constantly?
Jan 29, 2019
12
Specifically, the card is an EVGA GTX 1060 6GB SC
My other specs are a Core i5-2400, Intel Desktop Board 02, 8gb DDR3 RAM, 4tb and 320GB HDDs, and a EVGA 400w psu, and the HD Graphics 2000, while not primary, is still on so I can use my second display via VGA
Check your ram and pagefile usage during gaming sessions. I'd suspect you're hitting available ram limit there.
Also - would suggest you disabling integrated GPU. Currently this uses portion of system ram as vram for iGPU.
