so i got my pc next to my window which is always closed, but if i open the window.. is that ok? the wind wont bring any static bs or anything like that?
The only thing you need to worry about would be rain (if you forgot to close the overnight or went to school/work). There might be a bit more dust, but as long as you clean your system regularly, it should be fine.
If you are worried about static, don't place your computer case on a carpet area, keep it on a desk to prevent random static buildups. Connect it to a surge protector to minimize damage to your pc during a lightning storm as well
To make computer damage easier during a thunderstorm, connect it to an adjacent protector. To make damage least likely, connected to a completely different device (also called a surge protector). This other and properly earthed 'whole house' protector is the only proven solution for lightning protection. Why? Because it makes a low impedance (ie 'less than 3 meter') connection to single point earth ground. Near zero (ineffective) plug-in protectors do not have earthing, will not discuss it, and provide numbers that say it is only a near zero protector.
Numbers. Destructive surges are hundreds of thousands of joules. How many joules does the plug-in protector claim to absorb? Hundreds? Thousand? Could it be any more near zero - and many times more expensive?
Best solution for static electric protection is humidity. Humidity should be at least 40%. Another example of what useful answers always include - numbers.
