I immafrog1337 Honorable Jun 1, 2013 597 0 10,990 Aug 5, 2013 #1 is it ok to use compressed gas duster to clean a mouse sensor? http://www.newegg.com/Product/Product.aspx?Item=N82E16848043430
Solution nukemaster Aug 5, 2013 A quick blast to remove dust should not hurt it. You are not cleaning the sensor as much as a lens that is placed over it. If you are worried, keep the can just a bit farther away.
rgd1101 Don't Moderator Nov 7, 2011 74,852 4,242 176,290 Aug 5, 2013 #3 mouse sensor? Upvote 0 Downvote
G gbryan101 Honorable May 28, 2013 376 1 10,960 Aug 5, 2013 #4 I have done it and not had issues. Just be careful not to let the can blow extremely cold air on the sensor. Upvote 0 Downvote
I immafrog1337 Honorable Jun 1, 2013 597 0 10,990 Aug 5, 2013 #5 gbryan101 : I have done it and not had issues. Just be careful not to let the can blow extremely cold air on the sensor. so how far do u spray from the straw to the mouse sensor? Upvote 0 Downvote
nukemaster Titan Nov 23, 2004 19,623 6 74,965 Aug 5, 2013 Solution #6 A quick blast to remove dust should not hurt it. You are not cleaning the sensor as much as a lens that is placed over it. If you are worried, keep the can just a bit farther away. Upvote 0 Downvote Solution
G gbryan101 Honorable May 28, 2013 376 1 10,960 Aug 5, 2013 #7 About three inches. Honestly, a Q-tip with a bit of rubbing alcohol works better. Upvote 0 Downvote
