is it okay to downclock my 1600 mhz ram to 1333mhz to match with my other 1333 mhz ram?
These settings will be in the BIOS. Getting there will depend on what kind of motherboard you have. It's usually the DELETE key or F1
You can get all of the information from the RAM itself. It will have a sticker with this information on it. All values should be set automatically either way.
okay suppose i have to change it manually, then what r the things i have to do?
what will be the voltage,latency and eveything?
