If yes, does it matter what side (Left or right) I plug it in? Do I plug it into the socket that says "SYS_FAN"?
Photo of 3-pin connector: http://forums.techguy.org/attachments/221710d1363225182/3pinfansensor.jpg
Photo of 4-pin socket (Ignore the "CPU_FAN" text in the image): http://www.pcstats.com/articleimages/200801/LGA775install_pwm.jpg
My mobo is Gigabyte GA-78LMT-USB3
Link: http://www.gigabyte.com/products/product-page.aspx?pid=4305#ov
Thanks a bunch in advance.
