[SOLVED] Is it okay to run my system without case fans?
Aug 30, 2020
I have a mATX case that doesn't have any fan mounts so im wondering if im better off without any fans.
My system:
Sapphire Nitro+ RX580 8GB
Intel core i5-7500
8GB RAM
Asrock H110m-hds
Help is greatly appreciated, thank you 😀
My system:
Intel core i5-7500
8GB RAM
Asrock H110m-hds
At least you got AC in your room and you set it to 16C or you open your case and blow it with fan I think it'll be fine. If there isn't any of them, then you'll be in nightmare of frying your component
I just built a decent gaming PC kinda like yours but I use AMD. At first, there's no case fan attached. Just CPU fan and GPU fan. Idle temp is 60C and gaming can be up to 87C and it throttling the GPU. After I installed 3 fan exhaust at the back and 1 fan intake at the front, it helps lower the temp. Idle...
My system:
Intel core i5-7500
8GB RAM
Asrock H110m-hds
I just built a decent gaming PC kinda like yours but I use AMD. At first, there's no case fan attached. Just CPU fan and GPU fan. Idle temp is 60C and gaming can be up to 87C and it throttling the GPU. After I installed 3 fan exhaust at the back and 1 fan intake at the front, it helps lower the temp. Idle temp 50C and gaming temp 65C ish.
Of course at first whenever you buy a case you won't get any fan or maybe just 1 - 3 at front. You need to install more at back for the exhaust. I think on your case you can install 1 fan at the back, and maybe you can remove the top cover and install 2 more fan case(?)(I'm not sure).
But for sure you need external fans case for your component not to be fried. My suggestion if there aren't any options for the fans and your pc temp still high, buy gaming pc case. There's many cheap one but with lots of fan case slots.
I just checked my pc case, turns out, theres a fan mount on the side and rear of the case. I think if i slap on an exhaust on the back and an intake on the side i should be fine. I think this solves my problem. Thanks !
Reactions: Rae Nelvin
