Is it possible for me to hook up 2 monitors, with only 1 DVI in my graphics card?
EliotEoff
6
Hey, I have an Antic 900 computer case. The graphics card only has 1 slot and it's a DVI. I use a adapter because I have a VGA cable. I recently got another monitor but I just realized that I only have 1 port, is it possible for me to hook up the other monitor?
unfortunately the case has nothing to do with the GPU (Graphics Processing Unit). we need to know the model of the motherboard in the system, the CPU and if the GPU in it is built into the motherboard.
you can download CPUz from CPUID and it can identify the parts.
typically no you cannot run more than one signal over a DVI or VGA cable.
http://www.cpuid.com/softwares/cpu-z.html
