Is it possible to bend CPU pins to fix RAM slot?
JoshTheTofu
I am thinking about buying a motherboard with bent CPU pins and these bent pins have rendered one of the RAM slots useless. If I manage to bend them back is there any hope of this RAM slot coming back to life? I have browsed various forums tonight but I have found nothing conclusive so I am not holding out much hope. Any infomation would be helpful.
Thank you for your time.
Why would you buy something that should be considered JUNK? You don't know what other, less obvious side effects these bent CPU socket pins have.
