I'm interested in building a small form factor PC rather than buying one. My roommate's got a pretty sick deal on a lenovo m91 and I just want to know if I could build one for under $400? I have no real part list and no spare parts at the moment.
I used to be a hardcore Borderlands player, but I switched to pc gaming for school. I also play GW2, Age of Wonders 3 (It keeps crashing) and endless space
So i went to pcpartpicker (been there for a while and tried to build a $1000 mid tower with only $400) and found this. Could I get your opinion on this? I also changed some things around on it as well and might just go with 500gb SSD from either Samsung 850 regular (not elite) or the Kingston. https://pcpartpicker.com/user/masonmat/saved/#view=NFtzK8
That build is ok at best. CPU cooler is not needed and the mobo is overkill if you don't plan to upgrade to a quad core i5 in the near future. The PSU is also low quality (not great).
PSU? What's that? I don't understand the small things as I do see the larger things for a computer. Clear example is PSU.
The PSU (power supply) is one of the most important parts of your computer. This unit is what "processes" the power coming from your power outlet into your main components like hard drives, graphics cards, and motherboard. If this unit goes out, your entire PC could be killed along with it. This is why getting a very high quality unit is a MUST.
When looking up a PSU, don't go just by the 80+ ratings, rather look up lots of reviews on which PSUs are best. Seasonic and EVGA are currently on the top of that list.
If you have a micro center near your house you can actually get the combo deals for their CPU and Motherboards. They give $40 off of AMD combos and $20 off for Intel combos. With the $40 savings you can even drop a 120GB SSD into your build for your OS to really speed up your PC.
I'm going to go to microcenter this weekend for another project for my car, but I'll look into it. My buddy also told me that there is a sale going on, so if I do get parts, would Microcenter stack the $20 combo per part (MOBO, video card, HDD, etc.) or would they take the $20 off my entire purchase?
A little over budget, but this little setup would give you 40-60 on newer titles at 1080p.
http://pcpartpicker.com/p/tx7Fzy
How do you do rebates? I never really did a rebate before in my life, and I have no idea how to do one. Is it really worth it?
Its very easy, you normally just go online and register your information and print out a form. Then you make a copy of your invoice / packing slip and cut the barcode on the box of the thing you purchased and mail it in.
The combo is when you buy a CPU and Motherboard (they have to be compatible though). They just take it off your total when you pay.
