Question Is it possible to change a wireless headphone's internal audio output ?
Oct 26, 2023
4
This might be a dumb question but I recently got some anime themed wireless headphones where a character's dialogue will play when the headphones turn on, turn off, or when it has low batteries. (Like you know how wireless earbuds go Low Battery please charge every 10 seconds). However this product is from China so the dialogue is in Chinese. Is it possible to somehow modify the audio files and insert the English dialogue instead?
if the manufacturer doesn´t support it, then no
anything in the manual that say "change language" settings or similar?
have a look at the support homepage of your headphone´s manufacturer, eventually a firmware update provides other languages
email the support of your headphone and ask kindly for an update :)
It's a custom fanmade item using the Arvin brand (So it's not official merch) and it uses the official in-game dialogue for the few features. I can try emailing the store though.
try:
It's a custom fanmade headphones and the in-game voicelines are fixed in Chinese. Was wondering if its possible to manually upload the audio files within the headphones if possible.
I contacted the store and they said they can't change it and said to try to DIY but wont guarantee the results. Prob will have to look for a specialist then.
