B Basinho0211 Prominent Apr 6, 2020 39 1 530 Apr 28, 2020 #1 Is it a possible that I can change my ROG G20AJ’s (i7-4790 3.6 GHz, GTX 960) to an 8-pin adapter instead of a 6-pin? I want to change my graphics card to one that requires an 8-pin connected.
Solution ex_bubblehead Apr 28, 2020 Yes, replace the power supply with one that has the proper connections.
ex_bubblehead Titan Moderator Aug 24, 2012 17,746 2,216 89,240 Apr 28, 2020 Solution #2 Yes, replace the power supply with one that has the proper connections. Reactions: Basinho0211 Upvote 1 Downvote Solution
