Z zerosepte Reputable Jun 6, 2015 41 0 4,540 Apr 11, 2016 #1 ASUS Monitor 18,5'' Input signal: D-sub GTX 950 (MSI mini-itx) has: HDMI, DisplayPort 1.2, Dual-link DVI-I, Dual-link DVI-D.
Solution geofelt Apr 11, 2016 DVI-I includes provision for analog so you should be able to use a dvi-I to vga adapter or cable.
geofelt Titan Oct 9, 2006 56,061 4,859 174,240 Apr 11, 2016 Solution #2 DVI-I includes provision for analog so you should be able to use a dvi-I to vga adapter or cable. Upvote 0 Downvote Solution
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Apr 11, 2016 #3 +1^ http://www.amazon.com/StarTech-DVI-Cable-Adapter-DVIVGAMF/dp/B000067SOH Gfx cards used to come with one of those. I guess they figure that by now very few folks still use analog displays. Upvote 0 Downvote
SoNic67 Distinguished Jun 9, 2012 531 5 19,415 Apr 11, 2016 #4 Note that the adaptor will provide analog signal only when connected to the DVI-I port, not on the DVI-D: http://nvidia.custhelp.com/app/answers/detail/a_id/221/~/what-is-the-difference-between-dvi-i-and-dvi-d%3F Upvote 0 Downvote
