is it possible to connect second monitor into motheboard instead of gpu
It depends on: 1) If your motherboard supports IGPU Multi-monitor (alongside a dedicated GPU), and 2) If your CPU has integrated graphics.
If you are using Ryzen 1st-gen/2nd-gen CPUs or such other CPUs without integrated graphics, then, no display will come out from the motherboard video output ports.
