Hi folks,
Title says it all I've got the inwin 909 plus case which had 2 USB 3.0 header cables but my board only supports one. I noticed the board had the new type C header so is there a adapter I can get to change one of the cables to a type c header so I can connect it to that instead?
If you can what would be the ramifications? I'm assuming speeds shouldn't be affected but would it effect anything else?
If you can't has anyone used the 3.0 splitter cable? I know 3.0 only supports 2 ports so connecting 4 will bottleneck it but I don't really care I'm just using it to connect my keyboard and mouse so it's not really a big deal.
Thanks for the advice.
