Is It Possible To Get The Same Internet Speed Or Similar Internet Speed On A Wireless Connection?
Jan 28, 2014
106
The wireless connection that I use is pretty fast, but ever since I migrated from Windows 10 Home To Professional the speed is not so good. They're are not that many programs on it yet because I wiped it. So its not like I'm using a computer that needs a super overhaul. THIS ISSUE AT HAND is that I am not able to reset the router without going through my parents apartment. So here's another question. Is it possible to connect to the router wirelessly so if there is a connection issue it can be reset?Usually all it needs is to be reset and usually I'm really the only one using it 24-7. I know it might sound as if I talking in circles, but I just want to name all of the factors before I get a reply.I've discovered optimization software that supposedly works, but I don't know which one to get and I don't want to waste my time or money.I was hoping to find a hardware upgrade to make the connection faster and I HAVE done so already. I am pretty sure the adapter is connected (Wireless Alfa Network USB Long Range Adapter). The drivers are up to date and Windows is up to date. I actually use 3 Adapters in my Windows 10 Professional computer.I don't have any viruses. They're are not a lot of programs running. The computer is brand new. When I had Windows 10 Home I was able to stay connected for long periods of time without being disconnected to all 3 of them. Now I can only use 2. And yes my connection was strong by using all 3 adapters. I don't know, maybe that doesn't make sense, but honestly the speed was great considering I am one floor above my family. I have tried everything from soup to nuts and I still don't know what the hell is going on.
Wall of text condensed to...
Sort of. Wireless Administration.
However, this is turned OFF by default on almost all routers. This is a good thing to have OFF.
But if you mean "reset" to turn it physically off and on, no. That requires touching the router.
