I'm getting this because I need a usb hub, sd slot, and audio for my computer.
The only problem is that the reviews say the hub offers quite audio or even sometimes bad quality audio. I'm gonna test it out for myself just in case, but if the low sound is true -
Is it possible to give the hub more volts somehow like using a usb splitter and plugging one into my comp and the other into my computer?
If there is a good known way to do that, or even if just the idea in principle works, I would really like to know. Thank you!
(On a side not, I need the audio because my audio jack on my mobo recently got fried and I can't use them for audio like I traditionally would, so I have been looking for a good solution to that problem as well. This product just seemed to be the all in one deal so I got it instead of just a sound card and a separate sd card reader. I added this in just because I wanted to know if any of you thought there were any better options out there.)
