Is it possible to have more monitors than your motherboard and graphics card can fit?
cewyah
Okay, so the back of my motherboard and graphics card can support a combined 6 monitors. Is it possible to get around that without getting another motherboard/graphics card? Currently have 3 and, just curious. Is there such of a thing that'd almost be like an extension cable but with monitor slots?
can you explain clearly? getting a bit confused with what your question is, but i will answer based on what i get. usually if you plug a graphics card, the mobo display output were disabled, but some could be enabled, just check your bios first, if your motherboard display output can be enabled then it means you can just use both the graphics output from graphics card and the mobo, but note that how much display can you output depending on the individual components itself
