BenEzz Honorable Dec 27, 2013 194 0 10,710 Dec 30, 2013 #1 Hey all, is it possible to have one red led fan and one red blue led and one green led fan in my case?
Solution Dark Lord of Tech Dec 30, 2013 Sure , just make sure you can connect them to the board or molex for power.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Dec 30, 2013 #2 The case would help? Upvote 0 Downvote
BenEzz Honorable Dec 27, 2013 194 0 10,710 Dec 30, 2013 #3 The case would help? Sorry, Corsair 750D Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Dec 30, 2013 #4 Cooling (x3) 140mm AF140L fans, with room for up to eight fans . Upvote 0 Downvote
BenEzz Honorable Dec 27, 2013 194 0 10,710 Dec 30, 2013 #5 Cooling (x3) 140mm AF140L fans, with room for up to eight fans . Thanks, is it possible to have multiple colors of fans. So for example, could i have 2 fans red and another blue etc. etc. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Dec 30, 2013 Solution #6 Sure , just make sure you can connect them to the board or molex for power. Upvote 0 Downvote Solution
BenEzz Honorable Dec 27, 2013 194 0 10,710 Dec 30, 2013 #7 Sure , just make sure you can connect them to the board or molex for power. Could you recommend the best led fans? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Dec 30, 2013 #8 I like the Cougar Led Fans. Upvote 0 Downvote
