Is it possible to increase fps by 5 without overclocking and lowering the quality?
SirLipe
124
I want to play Rise of The Tomb Raider and on medium settings I have 25-30 fps in open world and 30-45 in caves, tombs. I want to have at least 30 fps no matter where. I have already overclocked my CPU.
I have :/
I understand the game to be cpu dependent.
I think a typical G3258 can be overclocked a bit higher with good cooling.
If you are using the stock cooler, a Cryorig H7 will perform better than the stock cooler.
If you are using the stock cooler, check to see that it is mounted well.
You should be seeing 10-15c. over ambient at idle.
If you take your case covers off, the cooler will get more fresh air to work with.
