hey so i was messing around with my lg 23mp55 60 hz 1920*1080 monitor and i found out that you can overclock it via amd adrenaline software. at first i put 75hz and the screen blinked for a sec and it was changed but then i tried higher numbers such as 90, 100 and up to 135hz and it took it and stayed in that refresh rate. when i try to put 144hz although, a screen pops up and says my monitor doesnt support that refresh rate. Does tis mean i just overclock it up to 135hz or am i crazy xd??? my concern is that it is change in adrenaline control panel but not in the dissplay advanced settings ( it shows 60 hz there) and also in the ufo screen test it says 60 hz. The screen movement seems a litle bit smoother. i will put an image of the adrenaline software.
View: https://imgur.com/a/FB7fGIi
i have an rx 5600 xt sapphire pulse card with latest drivers. THX
