Is it possible to raise the max resolution?
QuestinMarks
187
i noticed in the catalyst control center that there is an option called "My VGA Display".
In it i saw "Monitor Attributes"
with something checked ON ("Use Extended display identification data (EDID) or driver defaults").
i unchecked it and noticed that now, i could set my on Max resolution.
Is it a good idea to raise the max resolution to 1920x1080 (original 1600x1200).
or is this a bad idea?
if someone could explain this to me, that would be great
QuestinMarks
187
i can't access the monitor menu anymore, it's blocked and i can't unblock it, something wrong with buttons, (it's been this way for a long time).
the monitor always does a auto adjustment when the resolution is changed.
i just reinstalled CCC 10 hours ago, the only changes i made where the 2 things i mentioned on this thread and calibrated the color of both screen.
also i don't know where the scaling option is, let alone know if i even have one.
to you know where it is located for a VGA display or does it not matter anymore?
Kekoh
772
Overscan is only for digital connections, so you won't see that option for VGA.
QuestinMarks
187
so what can i do to make my screen fit in my monitor?
QuestinMarks
187
I accidentally clicked solved, My problem isn't solved yet.
to answer your question that was the first thing i tried doing, but my max is now 1600x1200 i can't go higher than that.
unless i use the method mentioned my starting post above.
AGAIN THE PROBLEM IS NOT SOLVED, I ACCIDENTALLY PRESSED SOLVED.
HOW DO I UNDO THIS MISTAKE, Could i mod set this as UNSOLVED?
QuestinMarks
187
believe if i knew, i would have fixed it.
but for some reason the unlock button (which is also the screen off and on button) doesn't work.
and i want to buy a new screen with HDMI connection but i don't have the money right now to buy one.
QuestinMarks
187
Well for some reason, when i opened my pc from sleep mode, i noticed that my screen fits perfectly in my monitor now.
so the "fitting in" problem fixed itself apparently. :)
there is however one last problem, which i think had something to do with the resolution problem that i was having.
for some odd reason whenever i try to place icons above my task bar of my laptops desktop, it goes 1 column up of the place i dragged it to. (see pic)
Problem now:
Before i couldn't place anything where the red zone is marked but now i can at least place 2 icons there.
how can i fix this problem
I don't see that as a problem really. Try turning off Auto Arrange in <RC> -> View -> Auto Arrange.
QuestinMarks
187
first off, thank you for resetting my thread back to unsolved.
second, i find this problem really annoying and i really like to know the cause of it.
i never used auto arrange, i checked and it's off.
if i put it on, the 2 icon's that i managed to place, jump to another place.
QuestinMarks
187
these are the things i know:
the align with grid option is still on
it's the auto arrange that's off
also interesting to know is, when there is a icon above the red zone i can place one in that zone for some reason.
i don't know for certain, but i think it has something to do with the placing of my screen.
in the option adjust resolution, you'll see 2 screens with nrs 1 and 2, you can move one of them up or down.
long story short i had all these problems (like losing native screen res, ccc option disappeared, etc...) and i tried random stuff.
somehow by placing them perfectly between each other (from under) i could place my icon's again.
then after trying to fix the other stuff (which all failed but now fixed).
the same problem came back only this time i was able to place some icon's in the red zone.
it also might be something totally different.
QuestinMarks
187
and how do i do that?
where can i change these dpi settings?
QuestinMarks
187
it's at 100% percent i can't go any lower
