C87756 Prominent Jan 6, 2022 27 0 530 Jan 13, 2022 #1 Hi guys I bought a cooler master cpu heat sink and fan. The fan is pretty rubbish but I can’t find one on the market that will clip on to the heat sink the same way.
Solution USAFRet Jan 13, 2022 https://www.coolermaster.com/catalog/coolers/cpu-air-coolers/hyper-h412r/#image-Item2 Is the clip thing removable from the stock fan? Probably. If so, it should be able to be mounted on any other similar size fan. And then, clip on to the fins.
SkyNetRising Titan Jan 4, 2016 32,707 4,807 126,640 Jan 13, 2022 #2 The clip is detachable from the fan. You have to unscrew it. Any standard same size fan is compatible ( 92mm fan ). The actual photo is for Hyper 212, but idea is the same. Last edited: Jan 13, 2022 Upvote 1 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,724 22,067 184,590 Jan 13, 2022 Solution #3 https://www.coolermaster.com/catalog/coolers/cpu-air-coolers/hyper-h412r/#image-Item2 Is the clip thing removable from the stock fan? Probably. If so, it should be able to be mounted on any other similar size fan. And then, clip on to the fins. Upvote 0 Downvote Solution
