[SOLVED] Is it possible to run a game requiring shader level 5.0 and higher with a shader level 4.1 GPU ?
Shalou
108
5
4,595
Hi, my friend owns a gt 320m and this game we want to play "One-armed Cook" requires shader level 5.0 and higher. She tried using dxcpl.exe to overcome dx11 issue but can't fix the shader level thing. Is there a software to change shader level of a game?
D
No, it's not possible technically. Even though the GT 320M supports DirectX 11, the feature level is only 10_1, which can create issues with many DirectX 11 & DirectX 12 titles.
I said technically. DirectX actually maintains backward compatibility with previous versions, so DirectX 12 is backwards compatible to DirectX 9.
There is a chance that your video card will not be capable of running a game that requires an advanced Pixel Shader model, even if your card meets the minimum DirectX requirements.
;-; alright thanks for helping out. ^^
