sorry could you tell me how many rpm the curve of a be quiet dark rock pro 2 is adjustable (because on pcpartpicker it gives me only 1500 RPM speed instead on models like the noctua NH-D15 it tells me 300-1500 RPM? second question: is it possible to make a group of fans change the speed in the same way as the others? I explain better if I have the be quiet that varies the speed according to the temperature of the CPU, I can vary the speed of its fans to automatically vary the other fans close? for example if the heatsink goes to 1000 RPM I would like one fan to go to 1200 and the other to 800, then if the be quiet goes to 1100 RPM the other 2 fans automatically go to 1300 and the second 900 RPM Is this possible?
