Hi folks!
I just found out that my graphics card is SLI ready (the Zotac GTX 970) thankfully so now all I have to do is upgrade my motherboard and power supply for overclocking and SLI. I just got a good cpu cooler for my i5 4690k but I need more power. I was thinking about how the Corsair 900D case has room for two power supplies cause it is freaking huge! My case is the Fractal Design Core 2300. I was thinking that with a little bit of modding I could remove the CD drive bays since I don't use one any way. I have an external CD Drive if I need one and Steam of course. Anyhow basically I have enough space for a top mounted PSU or a bottom mounted PSU. Right now I have a bottom mounted power supply (EVGA 500 watts 80 +Bronze certified, etc) for my single card. I was wondering if I get a new motherboard if it is possible to simply buy a second 500 watt psu instead of replacing it with a higher wattage psu. That way I would have 1000 watts in my system and it should power 3-way SLI and overclocking. I am going to start off with 2-way SLI and save up for a third card. The 980 and Titans are too expensive. 🙁 So yeah, that is my question: Is it possible to add a second power supply? Or can you only use one? Is it too dangerous for all the components to use two PSU's?
Many thanks in advance!!!
