Hi guys I just built a new rig and I am trying to push overclock for the first time in my life.
My set up is
cpu: i7 9700k
mb: Rog Maximus xi here
ram: Corsair Vengeance rgb pro (oc to 3500hz cl15/15/30/420)
gpu: Aorus RTX 2080 Xtreme
psu: Thermaltake irgb 850w platinum
cooling: evga clc240
case: Thermaltake p3
I have oc the ram without much problem, but when it comes to cpu I am not able to go any higher then 4.8ghz. If I put anything lower the 1.28v, my rig does not even start on anything above 4.8, but if put anything above 1.29, temperature rise up to 97’c during stress test
In order to go any higher then 4.8 at this point, what should I try or buy? Do you guys think i need better cooling?
My set up is
cpu: i7 9700k
