A Ahmed_23 Reputable Oct 4, 2015 16 0 4,510 Oct 4, 2016 #1 Can i clean my LED screen with glass cleaner which is normally use to clean mirror,glass ?? Is it safe to use?
Solution Hlsgsz Oct 4, 2016 Ahmed_23 : Can i clean my LED screen with glass cleaner which is normally use to clean mirror,glass ?? Is it safe to use? If it has alcohol, no, as ,depending on monitor, it may damage teh coating. Use special wipes or just something damp.
Hlsgsz Champion Feb 29, 2016 8,003 5 51,415 Oct 4, 2016 Solution #2 Ahmed_23 : Can i clean my LED screen with glass cleaner which is normally use to clean mirror,glass ?? Is it safe to use? If it has alcohol, no, as ,depending on monitor, it may damage teh coating. Use special wipes or just something damp. Upvote 0 Downvote Solution
das_stig Glorious Jul 24, 2009 8,631 221 46,390 Oct 4, 2016 #3 Cooled boiled water or ionized water on clean cotton cloth. Upvote 0 Downvote
