• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
[SOLVED] Is it safe to connect a monitor using hdmi to my cpu while a gpu is still inside the pci slot
Dillusion
94
So i think my gpu does not support secure boot and i accidentally enabled it in the bio and now i m getting blank screen and no console input devices found error(even with cmos reset) so i m planning to disable the setting myself by directly connecting my motherboard hdmi to it and going to bios. so is it safe to use that slot while my gpu is inside the pci slot?
R_1
Illustrious
Ambassador
yes it is safe.
eyes open. you MAY need to remove the GPU to enable the onboard.
it is safe to try, if nothing try removing the GPU then try again.
if its a BIOS setting clearing the CMOS will reset everything to defaults and should allow you to continue.
R_1
Illustrious
Ambassador
yes it is safe.
