[SOLVED] Is it safe to keep off front glass panel?
Apr 15, 2020
7
I have 3 intake fans on the ibuypower 973 on the fornt, it doesnt have good airflow for the fans when the front panel is on. The air flow is night and day when i take it off. Is it ok to just keep it off and only have the dust filter over the fans?
no problem there
did you check temperatures or is it just an air flow feeling?
Cpu temp is fine but could be lower using my h100i on my i7 9700k. But my rtx 2080 super is getting a bit more toasty than id like. Also, yes the air flow goes from hardly can feel to wind storm just from taking it off. My cooler is on the front as intake as well because it cant fit anywhere else
