[SOLVED] Is it safe to use psu cable splitter in my case
Aug 30, 2020
5
I recently changed my psu unit and now I don't have enough cables to power up my pc.
I bought chieftec gpe-500s eco series 500w psu.
Cpu is ryzen 5 2600
Gpu is AMD Radeon r9 290
Win 10, 4gb ddr4 gaming RAM
I also have 3 x ssd and that's all.
Sorry for poor config info but that's all I have becaise I can't power up my pc 😋
On online psu calculators, for my configuration calculations says that recommended psu is 488w
Problem is that my motherboard requires 8 pins and gpu requires 8 pins + 6 pins but psu have only 1 x 6+2 pins, 1 x 4 pins and 2 x molex.
I already attached that 2 x molex to 6 pins for gpu and don't have one more wire for motherboard.
And 6+2 pins connector only fits to gpu, not to motherboard.
Question is:
Is it safe to use splitters or what splitter type to use?
I'm imagined to use splitter 4 pins to 8 pins for motherboard because 4 pins cable is not in use but again, is it safe to do?
Thanks
Question is:
No.
If your current PSU does not have the required cables and connections for your hardware, you need a new PSU.
There is no other option.
I recently bought brand new psu in another country and now i can't go back to return it for return.
I bought it because online psu calculators says that I need 488w for my config. and man in store saya that chieftec is good psu.
The man in the store didn't have the foggiest clue what he was talking about. And even if he did, he much preferred his store to have the money and you to have the garbage PSU rather than the other way around. This PSU is garbage.
Thanks guys..
I use my pc generally for surfing, not for gaming.
Only have installed gta V
Can I use this config for surfing for now.
Maybe sometimes 1h of gtaV on low graphic?
