Mobo: ASUS P9X79:
It has 2 fan connectors that support PWM: CPU_FAN & CPU_OPT.
CPU_FAN connector supports the CPU fan of maximum 1A (12W) fan power.
CHA_FAN1-4 have +5V instead of PWM.
My plan is to use two PWM Y-splitters on the CPU_FAN & CPU_OPT, obviously. Using the CPU_FAN split for a Noctua NH-U12S + NF-F12 iPPC-2000 PWM Fan (push/pull);
and the CPU_OPT split for my rear chassis NF-F12 iPPC-2000 PWM Fan & front intake NF-A14 industrialPPC-2000 IP67 PWM
Noctua NH-U12S
Input Power 0,6 W
Voltage Range 12 V
Max. Input Power 2,16 W
Max. Input Current 0,18 A
Voltage 12 V
Voltage 12 V
EVGA SuperNOVA 750 P2 Power Supply
Will this work stable and safely?
Will I be able to control the speed of the 4 fans individually? (because 2x two fans use the same PWM-wire)
____________________________________________________________
NF-F12 iPPC-2000 PWM Fan: http://www.noctua.at/main.php?show=productview&products_id=78&lng=en&set=1
NF-A14 industrialPPC-2000 IP67 PWM: http://www.noctua.at/main.php?show=productview&products_id=83&lng=en
Splitters: http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026&cm_re=PWM_Splitter-_-12-162-026-_-Product
PSU: https://www.evga.com/Products/Product.aspx?pn=220-P2-0750-X1
Noctua NH-U12S
Input Power 0,6 W
Voltage Range 12 V
Voltage 12 V
Voltage 12 V
