J julius_18 Prominent Jun 30, 2017 7 0 510 Oct 8, 2017 #1 Can you mine any currency with 2gb card?? My card is gtx 770
Solution SoggyTissue Oct 8, 2017 you will only be able to work on small loads (because you got small amount of Vram) - you can, but your gain (if any) will be quite small.
SoggyTissue Estimable Jun 27, 2017 1,029 0 2,960 Oct 8, 2017 Solution #2 you will only be able to work on small loads (because you got small amount of Vram) - you can, but your gain (if any) will be quite small. Upvote 0 Downvote Solution
J julius_18 Prominent Jun 30, 2017 7 0 510 Oct 8, 2017 #3 How can i mine can you tell me? I've been looking software that can mine with my 2gb card but i've found none.. Upvote 0 Downvote
DSzymborski Curmudgeon Pursuivant Moderator Nov 19, 2010 21,127 5,272 106,640 Oct 8, 2017 #4 You'll likely make more money not attempting to mine at all rather than trying to mine with this configuration. Upvote 0 Downvote
